kreid
I was wondering if there was a way to bind the web interface to specific IP.
I have a server with two NIC's
Nic 1 - hosting site on port 80
Nic 2 - hosting lansweeper on port 8080
I would like to bind lansweeper to Nic 2 on port 80
Thank you
Could you contact us at support@lansweeper.com and provide us with a link to this thread and a screenshot of the configuration changes you attempted to make. One of our technicians will have a look at the issue.
kreid
Those are the steps I tried previously but receive the following error. Please see attached file.
Thank you for your help thus far.
Please do the following:
- Open the UltiDev Web App Explorer.
- Select your Lansweeper website.
- In the Network Addresses tab, select your HTTP listen address.
- Hit the Edit button.
- Select "Specify host name or IP address" and hit OK.
- Hit the "Save config changes" button.
kreid
Default
Which web server are you using? IIS or the default UltiDev?
