ehope
Hello all,
I have a couple of workstations that are actually acting as servers in my environment. In my reports they show up as workstations and I'm wondering if it is possible to change it so they show in my server reports. They are running Windows XP, which I am assume is the cause of the error. Thanks for everything. These forums have been invauable to me these past few days as I implement LS across my network.
Erik
In this case you will need to add the names of the computers or maybe the name of an OU that has only your servers.
ehope
Thank you for responding so quickly. Do you have any suggestions on how to accomplish. I'm not sure which parameters I should add. Thanks again.
Erik
It will only be possible if you recreate the server reports.
