abolus
hi.
how can i check or generate a report from lansweeper to check all the PC that is having acess to usb port and cd rom. i need to have the sample report below
PC name usb acess cd rom access date settings change
pc1 enabled enabled xxxxxx
pc2 disabled enabled xxxxxx
pc3 enabled disabled xxxxxx
pc4 disabled disabled xxxxxx
You can use the built-in reports below for this, found under Dashboard/Reports/All Reports.
Cdrom: Information
Port: USB
abolus
update please if such report is possible?
