jmarmo
When I try to run the :delete old users profiles command, I get this error
Error: File not found
I have delprof.exe installed on the user machine as well as the host. I even tried moving it to the root of c drive.
Has anyone else had the same problem?
Delprof.exe is a utility from Microsoft/Sysinternals.
You can find help on this forum : http://forum.sysinternals.com/
jmarmo
Okay, I figured out the path to delprof problem.
But now when I run it I get
"The network Path was not found"
The PC is on and has many profiles that can be deleted.
Any ideas?
Which is the action syntax?
