greylock
For security reasons, we do not want to use the default users provided in the instructions. Can we substitute user names with others that we wish to create for the purposes of scanning our network?
jwalters
Yes, you can create any username you feel like using. You'll just have to update the config files with the proper username and also have the username entered into SQL (in Databases | Security).
