ffA
I am getting the following error when I try to open the start.aspx page.
I have gone through the install several times now to check things over and I have tried to use the sa details in the web.config and I have scoured the forum and tried any solutions to similar problems.
I am at a loss as what else I can check Please help.
System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web30Homepage'.
Lansweeper : Digital dashboard
at DreamweaverCtrls.DataSet.DoInit()System.Exception: The DefaultView was requested but no tables yet exist.
at DreamweaverCtrls.DataSet.get_DefaultView()System.Data.SqlClient.SqlException: Could not find stored procedure 'dbo.web30Homepage'.
ffA
DOH!
thank you for that, I knew it would be something simple that I had missed.
Your startpage should be default.aspx instead of start.aspx.
Could you try this please
ffA
I can add machines to the database with the batch file
Congratulations, your lansweeper service is running
In queue: 0
In process: 0
Threads running: 0
Total processed: 3
So I guess it is an IIS issue
