JM
In Management Console - Configuration - Allowed Software tab, the following error appears when I add a software already approved :
Violation of PRIMARY KEY constraint 'PK_tblApprovedSoftware1'. Cannot insert duplicate key in object 'dbo.tblApprovedSoftware'
No more action is therefor allowed in this tab. I need to close the Management Console and enter again to continue software approval (carefully).
PS : very nice version
Regards,
JM
The fix is included in 3.1 (you can download the beta upgrade from the forum)
kevinpgreeley
Is there a fix expected for this issue?
KG
Good point, I'll fix this in the next release
JM
You're right. But if my selection is done on multiple softwares, all are not approved. Only softwares before the duplicated key are inserted, not those after.
JM
or you can press the escape key 😉
this will delete the duplicate row.
