mrdaytrade
After upgrading to 4.0 I am having trouble with the Lansweeper Server Service. I tested the beta version on a seperate server with no problems until the latest 4.0 beta. The http://betalansweeper:9524/ page fails to load after about 20 minutes of running. At first I thought it was something with the test server. However, after the 4.0 final release I updated the production server of Lansweeper, shutdown the beta server. The same thing happens on this server. When I look at the service it shows that it is started, but when I click on Service Status on the main page of the Web Console, page can not be displayed appears. I also have Active Scanning enabled and I use the LSclient, as I have been. The only way to correct the problem is to restart the service. This is what my error log says...
12 REPLIES 12
After you restart the service, do you get the same error?
mrdaytrade
Sure did.
Did you also upgrade lsclient to the latest version?
