it11
Hi All,
I apologize if this has been asked before. I had implemented LS 3.1 a while back and used the lsclient.exe in a login script. I was getting all the updates about users that logged into the machine. I wanted to go to the AD integration so I uninstalled 3.1 and made a fresh LS 3.2 implementation against Active Directory. I get all of the machine information I was looking for but I'm not see the logged in users now. Is there a tweak I can do to get that information as it was extremely helpful. If I need to go back to lsclient to get the functionality I will but I'd rather stick with the AD integration.
Please advise...
Thanks!
Travis
1)Yes, most people use both
2)You must remove it manually from lansweeper (if you want to, some people keep it as "history")
it11
May be a dumb question but can the two run in conjunction. I don't see why they couldn't. Also, when a computer is removed from AD does it get removed from LanSweeper or is that a manual task?
Thx
TR
The Active scanning cannot show the logged in users, for this you still need to use the lsclient.
