Simba
Greetings!
I've set up Lansweeper server on Win2003Server+SQLServer2k. Client successfully connects to server, but then I have a bunch of
"(XXXX) Cannot insert the value NULL into column 'Lastchanged', table 'YYYY'; column does not allow nulls. INSERT fails."
errors in the server log file. Only "LOGON" table is updated, all other tables are empty. (where "XXXX" and "YYYY" - all category and table names)
I'm absolutely new to SQLServer, so I beg you to help me. I'm almost sure I've made some mistake in SQL configuration, but I cannot find it.
Simba
I've downloaded and applied new script. Everything seems to be working now. 🙂 Thanks guys!
I've uploaded a new lansweeper.zip file, please reapply the database script (now with defaults included)
Looks like the default value for the field "lastchanged" isn't filled in.
The default value should be getdate().
Can you check if you have a default value for this column?
I'll take a look if there are any errors in the sql script.
