DanPerlman
Hi All,
I'm trying to find out what computers don't have SP3.
The report TSQL is:
SELECT
dbo.tblOperatingsystem.Description,
dbo.tblComputers.Lastseen,
dbo.tblOperatingsystem.Version,
dbo.tblOperatingsystem.ServicePackMajorVersion,
dbo.tblOperatingsystem.Computername
FROM
INNER JOIN dbo.tblComputers ON (dbo.tblOperatingsystem.Computername = dbo.tblComputers.Computername)
WHERE
dbo.tblOperatingsystem.Version = '5.1.2600' AND
dbo.tblOperatingsystem.ServicePackMajorVersion <> '3'
The query runs in SQL MGMT Studio and in LSBuilder.
When I try to run it from the web console I get:
Server Error in '/lansweeper32' Application.
Column 'software' does not belong to table theTable.
Description: An unhandled exception occurred during the execution of the current web request. Please review the stack trace for more information about the error and where it originated in the code.
Exception Details: System.ArgumentException: Column 'software' does not belong to table theTable.
Source Error:
The source code that generated this unhandled exception can only be shown when compiled in debug mode. To enable this, please follow one of the below steps, then request the URL:
1. Add a "Debug=true" directive at the top of the file that generated the error. Example:
<%@ Page Language="C#" Debug="true" %>
or:
2) Add the following section to the configuration file of your application:
<configuration>
<system.web>
<compilation debug="true"/>
</system.web>
</configuration>
Note that this second technique will cause all files within a given application to be compiled in debug mode. The first technique will cause only that particular file to be compiled in debug mode.
Important: Running applications in debug mode does incur a memory/performance overhead. You should make sure that an application has debugging disabled before deploying into production scenario.
Stack Trace:
[ArgumentException: Column 'software' does not belong to table theTable.]
System.Data.DataRow.GetDataColumn(String columnName) +1775301
System.Data.DataRow.get_Item(String columnName) +13
ASP.it_cust_aspx.__Render__control1(HtmlTextWriter __w, Control parameterContainer) +1276
System.Web.UI.Control.RenderChildrenInternal(HtmlTextWriter writer, ICollection children) +256
System.Web.UI.Control.RenderChildren(HtmlTextWriter writer) +19
System.Web.UI.Page.Render(HtmlTextWriter writer) +29
System.Web.UI.Control.RenderControlInternal(HtmlTextWriter writer, ControlAdapter adapter) +27
System.Web.UI.Control.RenderControl(HtmlTextWriter writer, ControlAdapter adapter) +99
System.Web.UI.Control.RenderControl(HtmlTextWriter writer) +25
System.Web.UI.Page.ProcessRequestMain(Boolean includeStagesBeforeAsyncPoint, Boolean includeStagesAfterAsyncPoint) +1266
Version Information: Microsoft .NET Framework Version:2.0.50727.3082; ASP.NET Version:2.0.50727.3082
There is no column "Software" in my query and the table "theTable" does not exsist.
Can anyone help me figure this out?
Problem confirmed, and fixed in the current 3.5.1 beta. http://www.lansweeper.com/forum/yaf_postst1514_Lansweeper-Service-351-update-1-beta.aspx
DanPerlman
Please let me know if I can provide any assistance.
We'll try to reproduce it
DanPerlman
Yes, I am on ver 3.5
It's just this one report that's having issues.
I have tried re-running the upgrade script and that changed nothing.
I have deleted and re-created the report as well.
Dan
Do you have version 3.5?
this was a bug in 3.2
