ESIT
The following displays when trying to access the web console after the upgrade. I copied over the new files, keeping the web.config as directed. The web console worked just fine before this. Here is what is now displayed:
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
13 REPLIES 13
ESIT
It's still there now and still getting the same errors from the 1st post. Here's the code with the entry you wanted:
<configuration><appSettings><add key="MM_CONNECTION_HANDLER_Lansweeper" value="sqlserver.htm"/><add key="MM_CONNECTION_STRING_Lansweeper" value="Persist Security Info=False;Data Source=US107VMIT01\SQLEXPRESS;Initial Catalog=Lansweeper32;User ID=lssqluser32;Password=mysecretpassword0*"/><add key="MM_CONNECTION_DATABASETYPE_Lansweeper" value="SQLServer"/><add key="MM_CONNECTION_SCHEMA_Lansweeper" value=""/><add key="MM_CONNECTION_CATALOG_Lansweeper" value=""/><add key="dateformat" value="MM/dd/yyyy"/></appSettings><system.web>
<customErrors mode="On"/>
<authentication mode="Windows"/>
<identity impersonate="true" />
<authorization>
<allow roles="exact-software\AMER IT System Support,exact-software\EMEA IT System Support,exact-software\APAC IT System Support" />
<deny users="*" />
</authorization>
<compilation debug="true" strict="false" explicit="true"><assemblies><add assembly="System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/><add assembly="System.Design, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B03F5F7F11D50A3A"/><add assembly="System.Web.Extensions.Design, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31BF3856AD364E35"/><add assembly="System.Windows.Forms, Version=2.0.0.0, Culture=neutral, PublicKeyToken=B77A5C561934E089"/></assemblies></compilation><httpHandlers><remove verb="*" path="*.asmx"/><add verb="*" path="*.asmx" type="System.Web.Script.Services.ScriptHandlerFactory" validate="false"/><add verb="*" path="*_AppService.axd" type="System.Web.Script.Services.ScriptHandlerFactory, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/><add verb="GET,HEAD" path="ScriptResource.axd" type="System.Web.Handlers.ScriptResourceHandler, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35" validate="false"/></httpHandlers><httpModules><add name="ScriptModule" type="System.Web.Handlers.ScriptModule, System.Web.Extensions, Version=1.0.61025.0, Culture=neutral, PublicKeyToken=31bf3856ad364e35"/></httpModules></system.web></configuration>
Add it after <system.web>
ESIT
Where do I do that? Here's the actual web.config that's in the website folder, the one I've been using since before the upgrade:
<authorization>
<deny users="*" />
</authorization>
Could you set the <customErrors mode="On"/>
You should see a better error description.
