radnak
Hi
Can I scan the computer automatically more than once a day?
This setup should work. Could you check what your scanning schedules are for these ranges. Note that each range has a separate schedule.
radnak
Thanks for your reply, but my problem is not solved
I have a licensed version 4.2.0.21. Scan only works with the method ip range scaning because computers are not in the microsoft domain but in samba domain.
I set the ip range scanning in two rows that contain the same address range and assign each a different time. it does not work
ip range
192.168.1.1 - 192.168.1.254 time: 23:00
192.168.1.2 - 192.168.1.254 time: 07:00
Yes, if you combine scanning methods. An overview of available scanning methods and how they work can be found on pages 41 and 42 of our online documentation. Scanning methods can be configured in the Lansweeper configuration console under Scanning Servers\(name of your server).
