ifm wrote:
If a laptop is started with the network cable and the user remove the cable just after login, will the scanner mark the computer as "RPC Unavailable" because it can not connect to the computer, or will that give another error?
At the time of scanning the service tries to connect to port 135 on the machines, if this fails at that time the machine will be reported as "RPC unavailable"
I suggest to try out the 3.5.1 beta version, it solves some RPC/active scanning issues.
http://www.lansweeper.com/forum/yaf_postst1514_Lansweeper-Service-351-update-1-beta.aspx
