ehorde
I am trying to build a report that will tell me if a system has a process running or not.
I can write a report that show me if a process is running, and also if a system is missing a process, but I am stumbling on the syntax of writing a report that tells me both states. e.g. - Yes or No.
Example output I am trying to get
Asset Name, Process Name, Process Running?
JoesComputer, SCCM, Running -or- JoesComputer, SCCM, Not Running
tables are tblAssets and tblProcesses
Here's my current non-working train wreck
Select Top 1000000 tblAssets.AssetUnique,
Case When Where tblAssets.AssetName Not In (Select tblAssets.AssetName From tblProcesses
Where tblProcesses.Caption = 'CCMExec.exe') Then 'No') (When (Where tblAssets.AssetName In (Select tblAssets.AssetName From tblProcesses
Where tblProcesses.Caption = 'CCMExec.exe') Then 'Yes') As [Status],
From tblAssets
Inner Join tblProcesses On tblAssets.AssetID = tblProcesses.AssetID
Thanks much in advance....
0 REPLIES 0
