itopssunrise
Durring installation the lsmanage.exe file throws error "Access Denied" while trying to overwrite it.
try to do a "icacls "C:\Program Files\Lansweeper\GUIConsole" /T /grant administrators:F" and still no luck changing permissions.
even tried a subinacl /file "C:\Program Files\Lansweeper\GUIConsole\lsmanage.exe" /setowner=******
Itopssunrise, please contact us through email about this issue.
Our email address is support@lansweeper.com
Srikanth08
i upgraded to 4.2 no issues..it is working fine..
Regards, Srikanth08
itopssunrise
im running a process viewer and that file path doesn't show up at all with being in use or opened. while viewing the properties of that file im not seeing a security tab like i should and do on other files.
Most likely the file will be in use by someone.
