paprita
Easy question: the name I choose for virtual directory during installation, should be the same that I choose later when I have to create it on IIS?
Could you please post or send some screenshots showing this behavior please.
paprita
When I launch installation application it ask to choose where to create the virtual directory; there are 2 option: under default web site or separated web site. If I chose the second one, it create the virtual directory under default web site, as it doesn't recognize my choose.
What do you think 'bout that?
When you choose the name for the virtual directory with the installer, the installer creates it for you in IIS.
