10-30-2019 04:50 PM
Solved! Go to Solution.
11-01-2019 02:43 AM
06-30-2023 12:58 AM
it seems things have changed. I have gotten a few different errors trying the ways stated above I have not used the xml since it involves using .msi and I can't use that due to the bug with .msi install.
I have gotten Result: Deployment ended: The filename or extension is too long. Stop(Failure). Credential: (). ShareCredential: (). Command: "\\server\DefaultPackageShare$\Installers\SentinelOne\SentinelOneInstaller_windows_64bit_v22_3_5_887.exe" /q /SITE_TOKEN===
also Result: Deployment ended: The filename or extension is too long. Stop(Failure). Credential: (). ShareCredential: . Command: "\\server\DefaultPackageShare$\Installers\SentinelOne\SentinelOneInstaller_wind_v22_3_5_887.exe" /SITE_TOKEN=== -q -f -b
11-21-2019 06:15 AM
11-21-2019 05:49 AM
11-21-2019 05:26 AM
11-21-2019 05:23 AM
11-20-2019 11:27 PM
11-21-2019 12:34 AM
TapdatMouse wrote:
Hey folks,
I am also trying to do a silent install. Mind helping me out here? I put the .exe on the package share via Lansweeper. I keep getting the following error. I have replaced the internal domain and site key with (xxxxxx) for security hygiene.Result: Deployment ended: Incorrect function. Stop(Failure). Credential: (xxxxxxx\lansweepersvcs). ShareCredential: (lansweepersvcs). Command: "\\C:\Program Files (x86)\Lansweeper\PackageShare\Installers\SentinelAgent_windows_v3_3_3_29.exe"/SITE_TOKEN=xxxxxxxxxxxxxxxxx== /SILENT"
"{PackageShare}\Installers\SentinelAgent_windows_v3_3_3_29.exe" /SITE_TOKEN=xxxxxxxxxxxxxxxxx /SILENT
<Package>
<Name>DEV.APP.SentinelAgent.v3.3.3.29</Name>
<Description>Test Package for TapdatMouse</Description>
<MaxDuration>900</MaxDuration>
<Rescan>True</Rescan>
<RunMode>2</RunMode>
<Steps>
<Step>
<Nr>1</Nr>
<Name>Check for Installer File</Name>
<Type>5</Type>
<ReturnCodes></ReturnCodes>
<Success>2</Success>
<Failure>-3</Failure>
<Path></Path>
<Parameters></Parameters>
<MSIName></MSIName>
<MSIVersion></MSIVersion>
<Command></Command>
<EditMode>False</EditMode>
<Conditions>
<Condition>
<Type>1</Type>
<SpecOne>{PackageShare}\Installers\</SpecOne>
<SpecTwo>SentinelAgent_windows_v3_3_3_29.exe</SpecTwo>
<Operator>1</Operator>
<Value></Value>
</Condition>
</Conditions>
</Step>
<Step>
<Nr>2</Nr>
<Name>Install SentinelAgent</Name>
<Type>1</Type>
<Success>-2</Success>
<Path>{PackageShare}\Installers\SentinelAgent_windows_v3_3_3_29.exe</Path>
<Parameters>/SITE_TOKEN=xxxxxxxxxxxxxxxxx /SILENT</Parameters>
<MSIParameters>/i /qn /norestart</MSIParameters>
<MSIName></MSIName>
<Command>"{PackageShare}\Installers\SentinelAgent_windows_v3_3_3_29.exe" /SITE_TOKEN=xxxxxxxxxxxxxxxxx /SILENT </Command>
<Conditions />
</Step>
</Steps>
<SoftwareVersion>7.0.110.2</SoftwareVersion>
</Package>
11-01-2019 04:35 PM
11-01-2019 01:28 PM
