‎02-09-2023 01:24 PM
I am trying to integrate Lansweeper in Jira, and have followed the guide (https://docs.lansweeper.com/docs/api/authenticate).
However, when I try the URL code i get the following error: "Failed to load site data, please ensure that you have entered a valid 'Lansweeper Identity Code' or make sure 'Lansweeper Identity Code' is not expired."
I am not sure what i am doing wrong, but I'm sure it is something silly.
Does anyone have any suggestions on how to resolve this? Or do I need to start practicing voodoo and do some rituals involving goats?
Solved! Go to Solution.
‎02-10-2023 11:17 AM
Hello there!
We presume that you need to use "Personal Application" instead of "Cloud Application". Then when you authorize site(s) you should get the "Identity Code".
Hello there!
‎02-13-2023 09:13 AM
Thank you for your response! It worked!
