FixitDave
I need to add custom attribute data to around 420 assets.
Is there a quicker way other than search, edit, change, save, repeat.
Scripting it with an SQL update script would be the easiest method. If you grab a list of all the asset IDs of the machines you need to update it would go something like:
Update tblassetcustom
set Custom1 = 'YourValue'
where assetid IN (1,2,3,4,5,6,7)
