bposiakow
I would like to ask if it is possible to massively add data to existing assets, I would like to add information to the created custom fields eg based on the computer name. What is the best way to do this?
Best regards
bposiakow
I understand that. All right thank you for an answer.
In order to mass edit or add data to assets you have 2 options:
  • Use the mass edit button in the left-hand pane on the assets overview page.
  • Write a database script to populate the custom fields.
I would recommend to create a backup of your database before performing any modifications. Backup instructions can be found in this knowledgebase article: https://www.lansweeper.com/kb/94/backing-up-your-installation.html
