08-06-2025 05:48 PM - edited 08-06-2025 05:49 PM
I am not on LANSweeper Cloud. I want to know if there is a way to adjust the Time to 12 hour instead of the default 24 hour clock.
08-07-2025 08:25 AM
Hello there!
Within Lansweeper, you cannot adjust the time. If you would like to raise a feature request for this, please raise a support case: https://www.lansweeper.com/contact/contact-support/
If you need technical support and have issues with accessing the Support Portal, please use this URL instead: https://www.lansweeper.com/contact/contact-support-case/
