adsbrown
Hi
I turned on "Manage all custom asset data in your site" and since then my asset groups are not working. The asset groups that are created and new ones I create are not showing in the asset groups on the site. Also the asset groups that are showing, seem to show the same thing, I change one and they all change to the same filter, and these asset groups are also not showing at all in the manage asset group section.
Hope all of the above makes sense
Any help any one give would be great
DavidPK
Hello there!
Our tech support team should be able to assist you with this.  Please open a ticket in our support portal.
Using the GatherLogs tool.
