Options
‎07-16-2018 06:24 PM
Dear Support,
I'm new to Lansweeper. I created an Asset group and want to create a rule that when a scan runs on a specific network (10.10.1.0/24), it automatically move the assets to the specific group that belong to 10.10.1.0/24.
Solved! Go to Solution.
Labels:
General Discussion
Options
‎07-17-2018 04:13 PM
I presume that you have created a static asset group under Configuration\Asset Groups. Such a group cannot add assets on it's own, as it can only be used to manually select and group assets.
As you want to automatically group assets based on IP address, we would recommend to make use of the IP Location groups on the same page. Here you will be able to fill in the IP address range, in your case 10.10.1.0 - 10.10.1.254. This will automatically give these assets the correct IP Location, whenever they are discovered with an IP within that range.
More information on grouping assets can be found in this knowledge base article.
Options
