‎05-14-2017 06:59 PM
Solved! Go to Solution.
‎05-24-2017 11:44 AM
‎05-15-2017 10:47 PM
Bruce.B wrote:
We've intentionally included assets of all states (not only active) to avoid potentially omitting vulnerable computers. That said, we are constantly adjusting the report to be more accurate, though we are leaning on the safe side as we'd rather have false positives then to let a computer slip through the cracks. The current version of the report in this post excludes Windows 10 computers on the Creator Update as they're deemed safe.
Regarding the Config\Windows\Quickfix information being blank on certain computers, if you've recently rescanned the "Quickfix" item on the computer, for instance via the Rescan Asset button which overrides scanned item intervals, the data should reflect what is found on the local computer. If you run the command below in an elevated CMD on the local computer in question you can verify the data, as Lansweeper scans KB information from this WMI class (Win32_QuickFixEngineering)wmic path Win32_QuickFixEngineering
‎05-15-2017 05:49 PM
‎05-15-2017 05:58 PM
shsheikh wrote:
Another change I had to make to the provided report was to only include active assets. That cut the results down by a little more than half.
Like 'Windows%' And tblAssetCustom.State = 1
‎05-15-2017 05:35 PM
‎05-15-2017 04:38 PM
‎05-15-2017 04:41 PM
Bruce.B wrote:
I've updated all reports in this topic to match the latest report. For future reference, use this forum topic as it will contain the most recent version of the report as more information about KB numbers comes in.
‎05-15-2017 04:35 PM
shsheikh wrote:
I have a big chunk of Windows 10 machines reporting back vulnerable. This includes my own laptop, which definitely is fully patched (creators update). Anyone else having a similar problem?
‎05-15-2017 04:54 PM
Do the machines show any data in Config -> Windows -> Quickfix? This is the issue i'm having where the table is empty.
‎05-15-2017 04:12 PM
