SW81
We have auto asset deletion set to 45 days for machines not "seen".  We have some servers that are powered off but still sat in Vcenter as machines.  The last successful scan is 50 days ago but the machines are not getting auto deleted as the esxi scan is making them "seen".  Is there a way to stop this happening without manually deleting the machine from Lansweeper or deleting the VM from Vcenter?  I was hoping the normal windows scan would be sufficient
SW81
Thanks, I tried to log a case but I get a blank screen when clicking on create case and now get an error.
Sorry an unexpected issue occurred, please follow the instructions below to notify our team.
  1. Open the sales webform https://www.lansweeper.com/contact/contact-sales
  2. Select I have a question about the Support Portal in the How can we help you today? box
  3. Type a full description of your issue in the Anything else? box and submit your request.
DavidPK
Unfortunately, if Lansweeper has an updated time stamp on the scan then we will not delete them.
If you submit a support case we can take a deeper look at this and determine is maybe a feature request can be made on your behave.
 Please open a ticket in our support portal.
Using the GatherLogs tool.
