cctech
My organization has over 1000 printers. For secure printing each device is assigned a printer. The printers are not installed locally. The devices print out to a specific printer based on application and routed via Citrix.
The list of printers and their devices can be exported to a csv file.
How can I import this csv file so the relationship can show up in the asset page?
Updating assets in general via CSV files is not yet possible. Using a database script you could do this. If you plan on going this way, you can consult the built-in report "Assets: Asset to asset relations" to find the database tables which are related to asset to asset relations.
Do make sure you create a backup of your installation before you start making database modifications, instructions can be found here: https://www.lansweeper.com/kb/94/backing-up-your-installation.html
