CharlotteA
I have the latest version of Lansweeper.
When I want to create or edit report, it stuck at the loading page.
I had the same thing with my old version.
Do you have a solution ?
If you're not running it on Windows server 2008 (non R2), then I don't know if anything can be done. I've seen that it might be an OS related issue.
If you are on a different OS version, you should be able to update to the latest Lansweeper version which will fix the issue.
CharlotteA
Here is the message that i get in the errorlog.txt
"3/18/2019 7:00:18 PM v|7.0.151.4| : (JSError) Url:http://srv-intranet:84/Report/editreport.aspx?det=web40repWMIAccessDenied&title=Error%3a+WMI+access+denied
Error: Impossible d’obtenir la propriété « Web » d’une référence null ou non définie
StackTrace: TypeError: Impossible d’obtenir la propriété « Web » d’une référence null ou non définie
at Anonymous function (http://srv-intranet:84/Report/editreport.aspx?det=web40repWMIAccessDenied&title=Error%3a+WMI+access+denied:169:17)
at l (http://srv-intranet:84/js/aqb/jquery-3.3.1.min.js:2:29367)
at Anonymous function (http://srv-intranet:84/js/aqb/jquery-3.3.1.min.js:2:29677)
IP: 10.1.101.209 Browser: Internet Explorer 11 Standard (Mozilla/5.0 (Windows NT 6.1; Trident/7.0; rv:11.0) like Gecko)
IIS Server
User: Built-in admin"
Sorry I'm french
Might be best to simply reinstall the web console: https://www.lansweeper.com/knowledgebase/how-to-reinstall-your-lansweeper-website/
Otherwise, send a ticket to support with your log files, that way they can check for errors.
CharlotteA
I tried with IE, Chrome, Firefox and Opera.. and i tried to restart the services too.
Yes, i have the problem with all reports.
What browser and version are you using?
Have you tried restarting the services (both Lansweeper and web service)?
Is this problem present with all reports?
