hhuber66
Hello all,
when looking at an asset like a Windows PC I am able to retrieve the information how much displays are connected to the PC.
Is there any way to get the information which interface is used to connect the monitor?
I would need the information if it is connected via VGA, DVI, Display Port or HDMI.
Thanks in advance
SIA_URM
Is this an information available in the latest LS version?
Unfortunately, since this information is not available in the asset's WMI classes or the registry. There is no way for Lansweeper to know if a monitor is connected using HDMI or VGA or any other method.
The best thing you can do is check what ports the assets have to connect monitors to. The ports information is stored in tblPortConnector.InternalReferenceDesignator
HDMI will be named: JHDMI
VGA will be named: JCRT
