nikola_djurdjev
Hi all,
I have two scanning targets. Active Directory Domain and IP range. I have a problem by having duplicate assets for same single physical asset. The root cause of problem are turned off Hyper-V machines. Once,they have been up and running and now they are turned off. Their names exist in Active Directory. Lansweeper creates 2 assets for each this turned off machine. One is with details found in Active Directory and the other one is created with details found on Hyper-V host which is hosting this turned off VM. The first asset created with data from Active Directory has unique key like: domain\srvXXX\1 while the second one created with data from Hyper-V has unique key its MAC address.
How can I solve this issue? How can I merge these two duplicates ?
Thank you in advance,
Nikola
swright
Did you ever get an answer to this?  I'm having the same issue.
