ojw_cryptomathi
I renewed my premium license today and restarted the service.
Now I have duplicate entries for some computers and with the software report of those computers are duplicate entries for some software.
Please advise what can be done to troubleshoot the issue?
Verify the following:
Your version of lansweeperservice.exe should be the latest version.
In your errorlog.txt file check for any database timeouts or errors.
Lstriggering the workstation should solve the problem (if no database errors or timeouts occur)
15 REPLIES 15
LS_Profile
Yes very good ! LSTRIGGER.EXE can remove the duplicate entries.
But i've 2000 computers. So from LS I've export in EXCEL a list of all computers then i 've used a excel macro to keep duplicate computers only.
You can found this macro here (in french cause i'm french 😉 😞
http://syskb.com/une-macro-pour-supprimer-localiser-les-doublons-dans-un-classeur-excel/
Once i've this list, i copy it in a computers.txt file. And i launch this script from command line:
for /F %%1 IN (c:\scripts\computers.txt) do lstrigger.exe SERVER %%1 DOMAINE 9524
All duplicate entries are now deleted !
Thanks!
LS_Profile
I've duplicate entry on "tblOperatingsystem" / "tblComputersystem" / "tblSoftware" / ... maybe others ...
Look the 2 last screenshots :
LANSWEEPER count 9 OS but if I click on it to see the details i see 17 items ...
LS_Profile
I've the same problem. I used the 3.5.2
I've a lot of duplicate entriesz. I can only select the first of them. If I delete the first entrie, the other is deleted too, so i lost all information about the concerned computer.
How can i mass deleted duplicate entries without deleted the good entrie. If you want i can send you part of tablespace if you want to investigate ...
LS_Profile wrote:
In which table did you get the duplicate entries?
ojw_cryptomathi
I ran the sql script and re-added the computer with lsclient. So far it looks ok...
That old topic was solved in the latest version.
I don't understand why you can't select one of the computers.
Could you try the following sql script
delete from tblcomputers where computername = 'yourcomputername'
ojw_cryptomathi
I did try that too. I can't select even one of the additional ones (they do not turn blue when clicked on).
I wonder if it is related to this old post:
http://www.lansweeper.com/forum/yaf_postst806_Double-entry.aspx
You can use the CTRL and SHIFT keys to select multiple computers.
