Gerardo8A
Hi everyone,
I have a detail when scanning with Lansweeper, Cisco Switches, it throws me the error of (Enable SNMP to scan Cisco devices) even when I generate a test with the Lans DeviceTester.exe tool. The test that I carry out is correct, since it shows me information from the SNMP.
The version I use is Ver3, I don't know if I need to activate something else on the server where I have Lansweeper installed, or some extra configuration.
Has this detail happened to someone else?
Anonymous
Not applicable
Hi Gerardo,
I had the same issue. Check your device type and wether it is exclude from scanning targets
