Nezrym
I attach the screenshot, how to fix?
On the database server you could try to reorganize the database.
There is also a stored procedure you can run:
"Execute psysrebuildallindexes"
Nezrym
Thank you.
Fixed.
Is it possible to translate the error in English please.
Nezrym
Has timed out. Timeout expired before the completion of the operation or the server is not responding.
problem with the database server
