Options
‎05-07-2019 10:52 PM
Trying to identify which assets are using the 32 bit version of Windows 10 Pro. If I search by OS, both version will display. There is an entry for System Type in the Config > Windows > System menu but that is not a searchable field.
How can I identify 32 bit systems?
Solved! Go to Solution.
Labels:
General Discussion
Options
‎05-08-2019 01:35 AM
Under Dynamic Groups, Doesn't That Have 32bit Windows (mine does), only shows those that are 32bit, then I can filter via OS type.
Options
‎05-08-2019 10:33 AM
For reporting you can also find this in tblComputersystem.SystemType
Options
Options
‎05-08-2019 01:45 AM
Mine does not, however, it does have a group for 64-bit systems. So I figured out how to create a new dynamic group and it does indeed let you filter based on Architecture.
Problem solved, thank you CyberCitizen!
Options
‎05-09-2019 01:54 AM
Your welcome.
I finally got rid of our last 32bit machine the other week. So much nicer. Can even be lazy with packages now and only package for 64bit installs 😛
