khog14
I am just starting with LanSweeper. I love the fact that Dynamic groups exist - but when you look at the individual asset - it does not indicate what group(s) it's a member of other than the default or any static group you've made it a member of. I am creating dynamic groups now, but I want to check to make sure all the assets that SHOULD be in the dynamic group are actually a part of that.....some of my groups depend on fields that are manually filled in - what if I forgot to fill in the info in the manual field? The only way I can see to do it is to export the list to excel and compare it with the full list of assets and see if it appears - extremely time consuming.
Is there a report I can generate (I am not very good with SQL queries) I didn't see one in the built in reports.
Any help would be appreciated.
nmulvihill
When you look at an asset page you should be able to see little tag of which group it is a part of. If not, the SQL to see what asset belong to a group is going to be as follows:
SELECT A.AssetName, A.IPAddress, AG.AssetGroup
FROM tblAssets A, tblAssetGroups AG, tblAssetGroupLink GL
WHERE A.AssetID=GL.AssetID AND GL.AssetGroupID=AG.AssetGroupID AND GL.AssetGroupID!=0
This is assuming you do not want the 'Default Group'
If you want to know the groups of a specific asset:
SELECT A.AssetNAme, AG.AssetGroup
WHERE A.AssetID=GL.AssetID AND GL.AssetGroupID=AG.AssetGroupID AND A.AssetID=XXX
Where you replace the AssetID with your criteria. If you want to search by name for example, replace 'A.AssetID=XXX' with 'A.AssetName=XYZ'
