filip_lauwereys
We are looking for stable solutions to get the Warranty discovery process running for as much as vendors as possible. Most of you know there is an ongoing issue with the exposed API of HP and it seems we will not easily get our hands on an API in the near future.
Knowing this, what are the vendors you are looking forward to a solution and do you have a link / path / info on the availability of an API that can be used. This may look like a strange question but the fact is that it is easier from a customer point of view to get access to a vendor API than from an ISV (at this moment in time)
When we are able to get this conversation going, we could make some custom(ized) solutions work.
Looking forward to your thoughts & ideas,
/Filip
steveb
MS surface warranty check would be a nice addition.
Surface warranty check
