swsswr
we have and EOL System which has MySQL 5.X running. Lansweeper found all the weaknesses. Great.
Now I turned off the MySQL Service.
Afterwards I  did a rescan of the asset, but still MySQL vulnerablities are shown.
So I assume Lansweeper just checks if product is installed, not running. Right?
cheers, swsswr
Obi_1_Cinobi
Hello there!
That is indeed correct. As long as it is installed, it will be detected. You can ignore the vulnerability though: https://community.lansweeper.com/t5/cyber-security-and-risk-insights/ignore-vulnerabilities/ta-p/647...
