05-17-2023 05:08 PM
Hello, I used this tutorial to switch from a localdb to an SQL server https://community.lansweeper.com/t5/lansweeper-maintenance/move-your-database-from-sql-localdb-to-sq... but now I canno't use Lansweeper at all. I can not connect to the web console as I used to, I changed my url https://144.1.....(ip of localhost).........:82/login.aspx to https://NewNameOfTheHostMachine:82/login.aspx but now it do not work anymore, I am a bit lost. Thank you very much.
Solved! Go to Solution.
05-18-2023 06:55 PM
Default Installation is SQLExpress/IISExpress - you moved the database to the new server, but the website is still using IIS Express on the old server (expected behavior). The URL would remain unchanged. You could post the error you are seeing, but you can also submit a support ticket to Lansweeper support - they have a nifty new log collector they will have you run that will bundle up all the info needed to send them.
05-18-2023 06:55 PM
