dpupard
I would like to manually review all assets and mark them as either approved or not approved. Then I would like to get a report or view showing all assets that are not approved. How could I accomplish this?
dpupard
Thank you for the reply. That is what I needed to know.
prighi61
You can either create two groups and assign each Asset to one of them, or you can use an unused or custom field to set one of two distinct (string or numeric) values. In the latter case you can use Mass Edit Assets.
