pseaton
I am trying the trial version staring today. I setup all my scanning on my domain with no issues. I have some switches on my wireless side that I would like to inventory. I did setup the LSagent for one server with no problem but I would like to scan a full scope for my switches. I don't see how to do that on another network.
Can you not put a scanning server in your wireless network? An additional scanning server would be able to scan the wireless network and just connects back to your main database.
Otherwise, yeah, LsAgent is also an option.
CyberCitizen
Honored Sweeper
Maybe using LSAgent to report etc, but you would lose deployment features if not on the same network / trusted etc
pseaton
This article looks like it will work if I was on the same network. Thanks for this info. My wireless side is on a completely different network. There is no communication between the two. I am hoping there is a way I would be able to scan both networks in the same database.
Is there a probe I can setup that will have a cloud connector? I have used that on our existing asset management software. I am looking for a better software and so far Lansweeper looks like it will do everything we would want except this last part.
If there is no trust between the domains you can follow this article: https://www.lansweeper.com/knowledgebase/untrusted/
You could also set up an additional scanning server in the other domain: https://www.lansweeper.com/knowledgebase/setting-up-an-installation-with-multiple-scanning-servers/
