SiStone
Within Lansweeper, is it possible to identify which ports on a switch are the members of a Trunk/Port Group?
We use primarily HP switches and this would be very helpful.
Cheers
Si
Not by default, you can find all the data Lansweeper scans from switch ports in the database documentation (tblSNMPInfo)
Most likely, the only way to get the data is to use Custom OID scanning.
