MAWAIS
Where can we find the Low-Level Architecture Diagram and High-Level Architecture Diagram of Lansweeper?
IainCaldwell
Not sure what you are looking for, if you can give more information or point to examples I might be able to help.
At the moment I'm using the diagrams here
Lansweeper Classic components and architecture - Installation - Lansweeper Community
I'm in the process of redrawing the main one, adding some of the relevant port numbers.
I'm then planning a table to describe the components, a table to describe the data stores, and finally, a table to describe data flows to crossing network boundaries.
I'll do that for classic/hybrid and then try and do the same for our next gen model.
Does that sound roughly what you need/want?
