Lewis_Spokane
Will the installer package run the Office Deployment Tool if the setup.exe and XML file are located in the PackageShare?
Because when testing I have to have the ODT on the local machine.
Lewis_Spokane
As of now my deployment has worked on my own local machine and a new laptop that was on the wireless network.
Every other machine has failed with:
Result: Deployment ended: Fatal error during installation.'
Return code is 1603
I think I can only assume its a network issue and nothing to do with Lansweeper. The package works, it's just a one line command and the command works if I run it locally. It has worked once, on a new laptop.
CyberCitizen
Honored Sweeper
Try scanning account. System accounts do not normally have network access.
CyberCitizen
Honored Sweeper
Are you talking O365?
I am deploying it using the following.
"{PackageShare}\Office 365\2016\OfficeProPlus\setup.exe" /configure "{PackageShare}\Office 365\2016\OfficeProPlus\Office365ProPlusInstall - Silent.xml"
All run from the server.
Hmm, I am doing as a command line.
\\server\Deploy\Applications\Office365\setup.exe /configure \\server\Deploy\Applications\Office365\Pilot_Admin_64.xml
When I deploy it to my own machine, through Lansweeper it worked fine. Deploying it to anyone else though gives me an error:
Result: Deployment ended: Fatal error during installation. Stop(Failure).
Which Run Mode do you use? I believe I chose System Account
