‎11-09-2017 10:47 AM
‎11-09-2017 01:18 PM
I'm 100% sure the culprit is Lansweeper (service). It happens always and only during the setup process (we did it 4-5 times).
We are using the Administrator account, I doubt it doesn't have the right permissions. However I will double check this too.
Thank you for your reply!
‎11-09-2017 11:38 AM
‎11-09-2017 11:47 AM
Charles.X wrote:
Wmiprvse.exe is used by all applications that use WMI. This can be Lansweeper or many others. Maybe this can help: https://support.microsoft.com/en-us/help/970067/you-find-high-cpu-usage-for-the-wmiprvse-exe-process-on-a-terminal-ser
If the installer gets stuck on Running Postinstall task - Sharing Packageshare folder. This would seem to indicate that maybe the user installing Lansweeper does not have the correct permissions on the computer to change sharing permissions on the packageshare folder.
