4 weeks ago
The latest Lansweeper integration is promising a streamlined and unified approach to ITSM. The integration is with ServiceDesk Plus, a leading ITSM solution from ManageEngine.
Now customers who use ServiceDesk Plus can view rich, accurate Lanweeper data and Vulnerability Insights reports right within the ServiceDesk Plus interface – no toggling necessary!
Our integration with ManageEngine’s ITSM solution eliminates the need to switch between platforms, saving time and reducing errors while providing real-time vulnerability insights and historical data directly within ServiceDesk Plus. This leads to faster issue resolution, better resource utilization, and improved cost control, ultimately enhancing IT service delivery and overall productivity.
Want to try it out for yourself? Learn more about how to set up and make the most of this powerful integration.
As always, please feel free to share your experiences and any questions you have with the rest of our community!
Solved! Go to Solution.
yesterday
@Alig26 what product in the Manage Engine suite were you hoping the integration would run with?
yesterday
We run ServiceDesk Plus on-premises
yesterday
Heyy @Alig26
best I can suggest is to raise the feature request with Manage Engine, they were responsible for the build of this integration with Lansweeper, and with your feedback they may be able to prioritise an addtional integration to the on prem version of Service Desk. If they are then for the Lansweeper side of the integration, you must be syncing with Lansweeper sites to use the integration.
Hope this helps,
Cass
Monday
I was really interested in this until I found out it's only for ServiceDesk Plus in the cloud, so complete let down.
yesterday
