warlock1663
Hello all,
Is there a way to print out or export all the IP ranges LS is scanning?
The simplest way would be to just look if they are enabled or not. If you have them all enabled you can take a look at the lastIPscan field of the table.
warlock1663
Thank you so much for the info.
Is there also a way to tell if the IP range is still activley being scanned?
You can do it with a report:
Select Top 1000000 tsysIPScanRanges.Servername,
tsysIPScanRanges.Ipstart,
tsysIPScanRanges.Ipend
From tsysIPScanRanges
If you want all the settings for that scanning target, you can also just select * from tsysIPScanRanges.
