StorageMgr
I've been copying serial numbers from a web-based GUI for another product we use, but I hadn't realized that it had a preceding space in the displayed entry. When I would paste the copied serial number, their search performed a trim, removing the preceding space. When I copied that to the Serial Number filter in Lansweeper, it would perform the search, not allowing me to correct the entry. The search result with "Nothing to display, click here to remove filters". This failed search screen has no horizontal scroll bar, so I am unable to correct my bad search term since the Serial Number column is off screen.
DavidPK
Hi StorageMgr,
Please submit a new support ticket through our official Lansweeper Support Portal so we can begin a detailed investigation. https://community.lansweeper.com/t5/support-portal/ct-p/support-portal
DavidPK
Hi StorageMgr,
