SimonHDV
I was just wondering why my Lansweeper Web UI stays all time in english even when the configuration corresponds to "FRENCH".
I didn't have this problem before upgrading few days ago to the version 6.0.100.75.
When I'm logged on (with full administrator account), I just click on the "gear" in the upper right corner to configure the language (from english to french) and it doesn't change anything...
Help would be appreciate.
Regards,
Simon
11 REPLIES 11
I downloaded the file and removed your link and pw as I don't want your log files to stay public. If I can't see anything immediately, I'll let one of our support guys contact you on the email address of your forum account.
SimonHDV
I took the liberty to re-open this ticket because we encounter this problem again...
You can find here the different files you asked for previous time :
Thank you in advance for your interest/time.
Best regards,
Simon
SimonHDV
With the new version, all seems ok.
Thank you for your quick replies.
Best regards,
Simon
SimonHDV
I'll try the update this afternoon.
I have already prepared the files you asked for.
I'll keep you updated.
Thank you.
Best regards,
Simon
If the Language setting in the user settings doesn't work I would send an email to our support team at support@lansweeper.com with an short description of the problem and the following files:
  • Program Files (x86)\Lansweeper\Website\App_Data\web_errorlog.txt, if it exists.
Just in case you can try and update to the latest version (6.0.100.87). However this will most likely not resolve your issue, but it might be worth the try.
SimonHDV
Ok, right. I understand all what you said, thank you.
But concerning my issue, I also try to change the helpdesk language in this menu (in the top right-hand corner on the blue cog) but it had absolutely zero effect on the helpdesk section.
Regards,
Simon
I see. The default language in Configuration\Translations is which language is set for new users you create. This will not effect you helpdesk language.
The Translations below are so that you can edit/create new translations. The "Enabled" button is to allow helpdesk users to select it as their helpdesk language.
To select your helpdesk language you need to use the blue cog in the top right-hand corner and select the correct language there.
Translation option
SimonHDV
Thank you for your help.
I have just checked in Program Files (x86)\Lansweeper\Website\lang
I have "lang.txt" which contains only english translations.
I have also lang_FRA.cfg and a lot of different languages (lang_FRA.cfg has the same content than yours uploaded on your previous post)
When I go the the lansweeper management web UI logged on with full admin account, I go to Configuration > Translations
The default language is "French" and if I change to english it works fine.
But when I look at the Translations > Languages, "English (English) (enabled/supported)" is ticked and I'm not able to modify field "Enabled", it's ticked and "grey" (unmodifiable).
When I try to change "English (English) (enabled/supported)" to "Français (French) (enabled/supported)", when I refresh the page, it takes back the initial configuration with "English (English) (enabled/supported)".
I hope that it seems more clear for you?
Thank you in advance.
Simon
Check Program Files (x86)\Lansweeper\Website\lang and open the the language file with a text editor to check if the file isn't corrupted, empty or no translations are added.
Alternatively I've added the default language files from my local installation to my post. You can try see if using mine works.
