Good morning!
After years of putting it off, I've finally started to dive into the location mapping feature of Lansweeper. I uploaded the floorplans that I have available, but they are fairly small. Well, small enough that having all of the assets for that location *on* the map makes it an absolutely cluttered mess of icons. For some of our offices, we have anywhere from 45-300 devices.
The zoom feature increases the sizes of the asset icons as well as the actual location image.
Is there a way to either shrink the asset icons (maybe change font size?) or to split the "zoom" feature in the location map to make it *only* zoom in the image, and not the asset tags/labels as well?
If not, please consider this a wishlist request, ha!
Thanks!
EDIT: I just saw the "toggle asset names" button, which def helps out, but Im still curious about the zoom changes.
