shrimpthelion
Hi, we're having trouble with scanning with LsAgent and LsPush after updating our Lansweeper to newest version (11.1.1.3). The relay with the LsAgent works wonders but it's choking our server, since all our assets scanning are coming from the relay.
LsAgent (10.4.2.0):
[5] INFO Url Check with address failed. Endpoint with address 'https://server.example.com:9524/lsagent' was not reachable: Unable to connect to the remote server
[5] INFO Connection to url https://server.example.com:9524 failed
LsPush (8.4.100.1):
Everything worked as expected before the update, no changes in network layer or windows firewall.
Ideas?
ErikT
Hi there,
If the scanning service is choked by the LsAgent imports, you could add an additional scanning server and make sure this scanning server is handling all other scannings.
Set up an installation with multiple scanning servers
Hi ErikT,
That's not a solution to our problem.
